Topic: Calling all Linux (ALSA) users!
Ladies and gentlemen, I have somehow stumbled across a strange
thing in my explorations of the Multiface 2. There exists a
simple tool in the alsa-utils called "speaker-test" which
you may have already used before. If you haven't, it is just
a "command-line speaker test tone generator for ALSA" which
"generates a tone that can be used to test the speakers of a
computer." (Man page http://linux.die.net/man/1/speaker-test)
For some reason, I decided I would run a series of test tones
of increasing frequency through the Multiface 2. I just made
a quick script that would run the same command in a loop each
time bumping the frequency up 1 Hz. Started at 40 Hz, so it
was just 40 Hz, 41 Hz, 42 Hz... and ended at 60 Hz. Simple
enough, right?
Well, for some reason things didn't go as planned and all test
tones below 50 Hz were somehow altered play at 50 Hz. Let me
put it another way: all of the 40-49 Hz tones that were requested,
were all played back at 50 Hz. Once the frequency value in the
script got above 50 Hz, things went normally and it played a
51 Hz tone, a 52 Hz tone, etc. (This may be easier to understand
by looking at the output from the script pasted below.)
So, I'm scratching my head. I'm wondering if the Multiface 2
could somehow be implicated, but that doesn't make any sense
since the specs have the frequency response rated down to
5 Hz (and the last time I checked 5 < 50).
Could this be a a built-in limitation of ALSA and/or the
speaker-test utility? Hard to imagine, but possible I suppose.
Unfortunately, speaker-test doesn't have a verbose or debugging
option so I couldn't coax much information out of it. I suppose
the next step would be to trace the system calls and then maybe
look over the speaker-test source code after that, but I thought
I'd check here first.
If you are a Linux user, would you mind please run this command
on your box and report back what results you obtained?
/usr/bin/speaker-test --channels 2 --rate 48000 --test sine --frequency 40 --nloops 1
Thanks very much!
luser@dawbox:~>
luser@dawbox:~>
luser@dawbox:~>
luser@dawbox:~>
luser@dawbox:~>
luser@dawbox:~> ./myspeaker-test.sh
Frequency is: 40 Hz
Command is: /usr/bin/speaker-test --channels 2 --rate 48000 --test sine --frequency 40 --nloops 1
speaker-test 1.0.14rc1
Playback device is default
Stream parameters are 48000Hz, S16_LE, 2 channels
Sine wave rate is 50.0000Hz
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 128 to 8192
Period size range from 64 to 4096
Using max buffer size 8192
Periods = 4
was set period_size = 4096
was set buffer_size = 8192
0 - Front Left
1 - Front Right
Time per period = 5.811834
Frequency is: 41 Hz
Command is: /usr/bin/speaker-test --channels 2 --rate 48000 --test sine --frequency 41 --nloops 1
Periods = 4
0 - Front Left
1 - Front Right
Time per period = 5.814871
Frequency is: 42 Hz
Command is: /usr/bin/speaker-test --channels 2 --rate 48000 --test sine --frequency 42 --nloops 1
Periods = 4
0 - Front Left
1 - Front Right
Time per period = 5.813361
Frequency is: 43 Hz
Command is: /usr/bin/speaker-test --channels 2 --rate 48000 --test sine --frequency 43 --nloops 1
Periods = 4
0 - Front Left
1 - Front Right
Time per period = 5.811889
Frequency is: 44 Hz
Command is: /usr/bin/speaker-test --channels 2 --rate 48000 --test sine --frequency 44 --nloops 1
Periods = 4
0 - Front Left
1 - Front Right
Time per period = 5.811520
Frequency is: 45 Hz
Command is: /usr/bin/speaker-test --channels 2 --rate 48000 --test sine --frequency 45 --nloops 1
Periods = 4
0 - Front Left
1 - Front Right
Time per period = 5.812000
Frequency is: 46 Hz
Command is: /usr/bin/speaker-test --channels 2 --rate 48000 --test sine --frequency 46 --nloops 1
Periods = 4
0 - Front Left
1 - Front Right
Time per period = 5.811633
Frequency is: 47 Hz
Command is: /usr/bin/speaker-test --channels 2 --rate 48000 --test sine --frequency 47 --nloops 1
Periods = 4
0 - Front Left
1 - Front Right
Time per period = 5.811498
Frequency is: 48 Hz
Command is: /usr/bin/speaker-test --channels 2 --rate 48000 --test sine --frequency 48 --nloops 1
Periods = 4
0 - Front Left
1 - Front Right
Time per period = 5.811774
Frequency is: 49 Hz
Command is: /usr/bin/speaker-test --channels 2 --rate 48000 --test sine --frequency 49 --nloops 1
Periods = 4
0 - Front Left
1 - Front Right
Time per period = 5.811662
Frequency is: 50 Hz
Command is: /usr/bin/speaker-test --channels 2 --rate 48000 --test sine --frequency 50 --nloops 1
Periods = 4
0 - Front Left
1 - Front Right
Time per period = 5.811806
Frequency is: 51 Hz
Command is: /usr/bin/speaker-test --channels 2 --rate 48000 --test sine --frequency 51 --nloops 1
Sine wave rate is 51.0000Hz
Periods = 4
0 - Front Left
1 - Front Right
Time per period = 5.811549
Frequency is: 52 Hz
Command is: /usr/bin/speaker-test --channels 2 --rate 48000 --test sine --frequency 52 --nloops 1
Sine wave rate is 52.0000Hz
Periods = 4
0 - Front Left
1 - Front Right
Time per period = 5.811861
Frequency is: 53 Hz
Command is: /usr/bin/speaker-test --channels 2 --rate 48000 --test sine --frequency 53 --nloops 1
Sine wave rate is 53.0000Hz
Periods = 4
0 - Front Left
1 - Front Right
Time per period = 5.811703
Frequency is: 54 Hz
Command is: /usr/bin/speaker-test --channels 2 --rate 48000 --test sine --frequency 54 --nloops 1
Sine wave rate is 54.0000Hz
Periods = 4
0 - Front Left
1 - Front Right
Frequency is: 55 Hz
Command is: /usr/bin/speaker-test --channels 2 --rate 48000 --test sine --frequency 55 --nloops 1
Sine wave rate is 55.0000Hz
Periods = 4
0 - Front Left
1 - Front Right
Time per period = 5.811936
Frequency is: 56 Hz
Command is: /usr/bin/speaker-test --channels 2 --rate 48000 --test sine --frequency 56 --nloops 1
Sine wave rate is 56.0000Hz
Periods = 4
0 - Front Left
1 - Front Right
Time per period = 5.811784
Frequency is: 57 Hz
Command is: /usr/bin/speaker-test --channels 2 --rate 48000 --test sine --frequency 57 --nloops 1
Sine wave rate is 57.0000Hz
Periods = 4
0 - Front Left
1 - Front Right
Time per period = 5.811751
Frequency is: 58 Hz
Command is: /usr/bin/speaker-test --channels 2 --rate 48000 --test sine --frequency 58 --nloops 1
Sine wave rate is 58.0000Hz
Periods = 4
0 - Front Left
1 - Front Right
Time per period = 5.811555
Frequency is: 59 Hz
Command is: /usr/bin/speaker-test --channels 2 --rate 48000 --test sine --frequency 59 --nloops 1
Sine wave rate is 59.0000Hz
Periods = 4
0 - Front Left
1 - Front Right
Time per period = 5.811635
Frequency is: 60 Hz
Command is: /usr/bin/speaker-test --channels 2 --rate 48000 --test sine --frequency 60 --nloops 1
Sine wave rate is 60.0000Hz
Periods = 4
0 - Front Left
1 - Front Right
Time per period = 5.811713
luser@dawbox:~>
luser@dawbox:~>
luser@dawbox:~>
luser@dawbox:~>
luser@dawbox:~>
