Topic: 9632 & 9652 issues
I'm running a 9652 and 9632 simultaneously. I'm aiming to master in Samplitude, using the analogue out from the 9632 into my outboard, then back in the analogue in of the 9632, then output from Samplitude using the SPDIF option on the 9652.
I've really struggled, but I've got it to work. I don't know how, but I'm taking screenshots, that's for sure.
However, I'm really puzzled.
The HDSP mixer will only show the first card (as determined by "Hammerfall DSP Settings / Global), which is the 9632 in this case. Is this normal?
In the matrix view, I have to set my outputs 1&2 to AN1& AN2. That's fine. But I don't need any inputs to come back in at all. Is this normal?
It's working, but boy is it complicated.
I've done a digital loop (for testing) and that works fine too, but weirdly, the recorded track is early compared to its source. And it doesn't null with the original, although it should. There's noise at -135dB. Not noticeable, but a bit weird. Is this to be expected?
