1
Topic: Updated: TotalMix FX 1.04 available
While all official driver packages now include TotalMix FX 1.03, version 1.04 is also available as separate download. It adresses some issues overlooked in 1.03.
- MIDI fixed for the newly supported 'old' interfaces, fixing also various related side effects
- Settings (F3) can not be opened with the AIO (Mac) and did not work correctly under Win. Chosing specific Talkback/Listen channels could cause more trouble.
- Improved device detection (sometimes a RPM was detected for no obvious reason).
- Fireface 800 default channels have been changed from AN 9/10 to AN 1/2 for Mains, and to AN 9/10 for Phones 1. These new values will only be set when TM FX is installed for the first time, or a Total Reset has been performed.
- Fix snapshot problem when using 9632 and AIO with analog input and output expansion boards
- Fix seldom order problem when using multiple HDSP cards
- Clear Submix (right mouse click) no longer deletes the submix of Talkback and Listen inputs
- and some more small stuff.
https://archiv.rme-audio.de/download/to … 04_win.zip
https://archiv.rme-audio.de/download/to … 04_mac.zip
Thanks for any feedback!
Re: Updated: TotalMix FX 1.04 available
You guys are really great, constantly bettering your Software! Thanks for that!
Please don't "forget" small improvements already on your list, like
http://www.rme-audio.de/forum/viewtopic.php?id=19103
Thanks!
Tab
Thanks for the update but midi still doesn't update the names in my display (phones 1,2,Main etc) when minimized to tray (top right red x) which it does fine when minimized to taskbar.
A short question: Can you introduce scaling options for the TotalMix FX windows that are below 100% - ideally using it for big mixing windows like with a MADI-card oder -interface? Also: Would it be possible to open two TM FX windows when two cards are in the computer? Currently this is not possible. It could be done like in DIGIcheck.
Thank you very much for constantly improving the already great drivers and tools!
5
You can open as many windows as you like and select the corresponding interface in them. So it is possible.
Links in post 1 have been updated with beta 4 Windows and the release version for Mac.
