Topic: hdsp 9632 - which new chipset?
Hi guys, i'd like to buy new computer to my hdsp 9632 card. Can someone tell me which chipset is best to work with my card. I was thinking about intelx99. I also would like to check list of required chipset to avoid any problems during working.
Re: hdsp 9632 - which new chipset?
The x99 has no support for pci cards. Only some boards with the intel z87 and z77 support pci.
Thank you so much. greets
http://en.wikipedia.org/wiki/List_of_In … GA_2011-v3
I  found out that z77 z87 doesn't support pci. It ony works via pci-e  to pci bridge which i want to avoid.
For a card with limited channel count like the 9632, this should not be a problem in terms of performance. If at all, problems might occur e.g. with the PCI MADI card.
Does it mean I can use any chipset i want on motherboard with PCI slot??
I use the 9632 on a z77 board no problem at all.
Thank you:)
