bienpegaito wrote:Thanks!
My problem is I just know enough to be dangerous ... "can work that way" makes me kind of nervous.
I live there myself (being dangerous...) - and that's how I learn
bienpegaito wrote:Or? Somewhere between preferences and 'best practices' there are some things I need to learn. Your preference is because this makes the system less susceptible to jitter?
Indeed - Somewhere in-between. The gear itself will dictate a lot of it, and then best practices and personal preference (to ward off the OCD! ) go into an initial layout. Test the layout and see if it works reliably, and if the workflow meets your needs. Wash, rinse, repeat.
My main AD/DA converter is the system's wordclock master. Its BNC-OUT feeds the ADI648's BNC-IN with a Tee (unterminated), and then feeds the second AD/DA converter's BNC-IN (all using short 1-foot BNC cables). This second converter is terminated internally, so I decided to let that BNC chain end there.
Both converters feed the ADI648 over 12 ADAT I/Os (96 Channels worth).
ADI648 connects to MADIface-XT in my Primary DAW over MADI Optical (MADI port #1). I slave the MADIface-XT to this MADI input.
Then, the remaining 16 channels of ADAT I/O's on the ADI648 feed my V-Drum DAW with a Digiface. I'm only using the ADAT Outs from this V-Drum DAW (my DIY snake has 2x ADAT's, BNC and MIDI), so I slave the Digiface via BNC Coax from the ADI648's BNC-OUT (a re-clocked and buffered output).
Beyond that, I have a second VSTi DAW PC with an HDSPe MADI card connected to the MF-XT's MADI port #2 - This DAW is clocked over MADI Optical. "Steadyclock" cleans it up
Everything is solid while keeping my OCD tendencies in-check (mainly concerned about jitter with the main bank of AD/DA's, and that's covered as well as it can be).
bienpegaito wrote:If I plan to pretty much stick in the 44.1K world, would this be another plus for clocking from the MADI card? And in that case, would you recommend (similar to what I asked above) WC to the ADI 648 and ADAT from there to the ADCs and DACs?
I'm also a 44.1 guy. 88/96 is easily possible in my setup, but I'd have to change the way it's configured to get the most access to my analog I/O.
I'd say this is a reason to use your AD converter as your master. It's when you want the DAW to have control over the sample rate that it makes sense to let the DAW (your MADI Card) be the master. Since you stay @ 44.1K, you can let the AD converter be master and won't need to fiddle with changing rates manually at your converter.
I wouldn't sweat this too much - and don't waste cash on esoteric BNC cables and crap. Some descent Belden Video BNC cable is about all you'll need (if you even end up using BNC at all!).
Reliable rock-solid clocking is what you are ultimately after in the end. Set it and forget it. Make some music
2x SSL Alphalink MADI AX
