1
Topic: TotalMix FX 1.05 available
Version 1.05 for Mac and PC solves these issues:
- MADIface USB would not show up to 128 input channels
- Volume of Listenback input is saved
- Multiface: Loopback did not work on channels ADAT 7/8
Download:
https://archiv.rme-audio.de/download/to … 05_win.zip
https://archiv.rme-audio.de/download/to … 05_mac.zip
No installer. Exit TM FX, then copy the unpacked file to Windows\System32 or the Mac's application folder.
Re: TotalMix FX 1.05 available
I have a Multiface II and a Mac Pro (2007 model) which was running OSX 10.6 with Hammerfall software. Yesterday I upgraded my system software to 10.7 and downloaded TotalMix 1.04. It opened fine and both the mix and matrix windows showed up; however, it did not show up as an option in my system preferences/Audio settings. I downloadedthe 1.05 upgrade and copied the file to my apps folder. Now when I open TotalMix, neither the mix nor matrix windows appear, and it still doesn't show up in the Audio Preferences. Any idea what's up?
Thanks for the new version and fixes :-)
saenz.marcos23: you did not install driver 4.01?
I did, and reinstalled it again. How do I uninstall everything and do a clean re-install? Will that help? And why didn't it appear in Audio MIDI Setup?
6 (edited by jonahs 2014-12-04 07:53:35)
i'm not sure exactly at what version this happened, but i'm getting an issue in os x 10.10 where total mix fx causes kernel task cpu usage to go up to 15-20%. 2010. this is in addition to the ~5% total mix reports using mbp NVIDIA GeForce 320M 256 MB c2d 2.4ghz.
it might be happening after removing and then re-attaching ufx without a restart in between. it might have happened between 1.02 or 1.03, i'll try to check. i recently upgraded to 10.10 and it might have started then.
i'm also unable to open a total mix fx window without the ufx attached as i used to be able to do.
7
Current version is 1.05, included in USB driver 2.03:
https://archiv.rme-audio.de/download/dr … ac_203.zip
