Topic: HDSPe AES32 doesn't auto follow word clock SR any more?
Hi folks,
I've been using a HDSPe AES32 card for a while now, and have noticed that since the arrival of the v4 drivers, the sample rate doesn't automatically switch to a change in incoming word clock. If I change the sample rate on my clock master (Mytek ADC 192), I have to also manually set the same rate using the HDSP settings panel, whereas with the v3 drivers it used to change automatically to follow external word clock.
Is there a reason this needs to be done manually now, or am I missing something? Thanks for the help.
