Topic: How to make work Digi tech on Mac ?
I have open digi tech and can't choose option Playback as I have witnes on Windows. Only Input avallible . Working on Logic X.
Any idea ?
Thanks Tom
RME User Forum → DIGICheck → How to make work Digi tech on Mac ?
Any idea ?
Thanks Tom
The Mac version does not support this. Use the mixer's internal loopback to make signal available at the input.
Can You explain to me please how to do it in Totalmix ?
Thank you
Tom
If you have installed the latest driver with Totalmix FX, the Loopback option is in the channel settings of the physical outputs. It will route signal back to the corresponding input. Which device are you referring to?
Fireface UCX.
