Topic: Can't assign babyface control knob for ADAT 3/4 level changes
It perfert works with PH 3/4, but don't work if I use ADAT 3/4 as main out.
I use MacBook Pro and also assign system level regulation (F11\F12) via Audio MIDI Setup, so and sutuation is the same.
Re: Can't assign babyface control knob for ADAT 3/4 level changes
That is a hardware limitation. The knob can only control the analog outputs. Quite logical als there is no way to select 'ADAT'
on the unit.
3 (edited by desmusic 2015-01-15 11:54:45)
I thought that knob it's controller which controls the software. So, Is there any way to regulate ADAT level without open TotalMix window? (maybe system routing via "Audio Midi Setup")
It's so important for me, because I work sometimes with fullscreen software and it's inconvenient to exit for level changes.
That knob controls the hardware directly and sends the current information to TM FX as well...no way around it.
