Topic: HDSPe MADI Alsa Arch Issues
Ive recently installed Arch linux onto a Dell Server, the server runs a RME HDSPe MADI card. Im using Alsa and i dont want to use anything else i know it is fully supported but im running into a few issues. The main issue is i can play wav files using aplay but it seems to be playing in fast forward, a skipping strange speed. Also to confirm that, i ran a YouTube video and the entire video ran in fast forward about 2 seconds to 1 real second.
Also the card is showing a solid red LED on the back. I am using the standard drivers alsa has allocated. Im wondering if i need to setup an ~/.asoundrc file which i dont have currently as i have struggled to get it to work correctly. The alsamixer has various settings which i have adjusted single and double speed with no results. Any help would be much appreciated. Cheers.
