Topic: Best RME products combination for realtime playing
I wonder what is the best RME product (or products combination) for my use case.
Main use case is realtime VSTi playing using lowest possible latency (single miliseconds matter) and some recording. It is going to be used with standalone Win7 PC. Again, low ASIO latency and glitch free operation is critical.
I need:
* some analog inputs (at least 4)
* Hi-Z input
* some analog outputs (at least 4)
* headphone output
* midi in (at least 2)
* I/Os should be on some external box
Fireface UCX seems to be perfect match but it is USB2.0/Firewire which gives a little bit worse performance comparing to PCIe if I understand it right.
Is there any RME product which combines UCX flexibility with PCIe performance?
Let's assume price is not an issue here :-)
Piotr
