Topic: Octamic D to the Unbalanced Inputs of a Recorder
Hello Knut or Daniel (or knowledgeable RME user),
I have 3 Octamic-D units, which I was hoping to use with a recorder with ADAT inputs. Unfortunately, I couldn't find one in the time and budget available. My new recorder is one with unbalanced inputs.
I've talked with a couple of smart people from the AES (I'm not one of them), and they've told me that I need to know the output configuration of the Octamic-D in order to know if I need any special adapters "at the source end" (the Octamics) to go from TRS to TS cabling.
Could you tell me please if I need to make adapters that tie tip and sleeve together, or ring and sleeve, or any other configuration. I'm not so worried about the dB loss, altho I would like to know what to expect. I'm more concerned with the fidelity of the signal.
With the recorder comes DB25-to-TRS/M cables -
http://i.ebayimg.com/00/s/NDUzWDgwNQ==/ … n/$_57.JPG
- and if needed, I would either alter the male TRS plugs for use with the Octamics, or make TRS/F-to TS/M adapters to your spec.
Thanks very much.
