Topic: EXT input on Remote advanced remote control doesnt work?
Hey guys,
For some reason the ext input button stays lit and doesn't function anymore with totalmix. If I deselect output 7/8 (the ones im using for ext input) in settings then the button isnt lit anymore but it still doesnt do anything. This is on PC win 7 with: UFX, totalmix 1.08, dsp_sw version 1.58, driver date 04.02.15, driver version: 1.069, hardware revision: 357
Now when Im using 'my mac with al the same recent software it DOES work...
What am I doing wrong?
Robin
Re: EXT input on Remote advanced remote control doesnt work?
Sorry, your description is confusing. You can not select an output for Ext. In, only an input. And is this about the signal not routed to Mains, or just the LED not working correctly? Also you might have changed the function of button F within the Key Command Settings.
3 (edited by robinhunt 2015-03-06 21:59:18)
Ha THX it was the input I wanted to select. The problem was indeed the function of button of not assigned in Key command settings... It works again!
THX
Can be closed wink
