1 (edited by filter_7 2015-04-06 10:47:14)
Topic: MIDI in led always active even with no key press
The MIDI in led of my Multiface 2 is blinking even if I don't use my MIDI keyboard.
If I disconnect the MIDI cable and then connect it again the led activity stops for a little.
I'm on Ableton Live 9 with Win7 32 bit.
Is it normal or should I check something else in my preferences?
Re: MIDI in led always active even with no key press
< new edited post >
Probably your keyboard is sending active sensing, a midi message used to keep connections eh active. Nothing wrong with that.
