Topic: Multiface I combi Expresscard and Sonnet ExpresscardCard 34 Thunderbol
I tried to use my old Multiface 1 with my Mac mini ( 2,3 GHz Intel Core i7).
But I did not managed to get it operated.
I hope it is possible for you to help me to analyze this problem.
I am using OSX 10.9.5 with driver 4.03 and rev 20.
The Express card is connected through the Thunderbolt port using Sonnet Echo ExpressCard 34 Thunderbolt.
First I want to know if the card is ok connected to exclude this function is ok.
The HDSP popup in I/O box give the information that the box is connected.
The in and output settings at my Mac Mini shows the card (Hamerfall DSP Multiface (22900828) but gives the information - There are no output settings available for this selected device.
Can you confirm an ok connection with this information for the hardware?
I am using the latest drivers. Do I need other drivers?  Or is there another problem?
Re: Multiface I combi Expresscard and Sonnet ExpresscardCard 34 Thunderbol
Everything looks fine. What do you see in the RME mixer, do the analog inputs show levels around -100dB?
What exactly does not work as expected?
