Topic: Mixing tracks together in Totalmix
Recently purchased the Fireface 802 and loving it to death! But…
Basically I'm trying to use Reaper to play back tracks through Totalmix, and mix within Totalmix.
I've managed to get separate tracks in Reaper playing back on individual playback channels in Totalmix, and in turn have linked these playback channels to separate output channels within TM.
I'm now tweaking the output EQ's/Dynamics, etc, on each track, but these adjustments are only taking effect in real time when I single a track out by selecting "Cue". As soon as I de-select Cue, it un-solos the track and the shaped EQ sound ceases in the monitoring sense. Basically i'd like to know if it is possible to cue multiple tracks at the same time?
Re: Mixing tracks together in Totalmix
Cue does not allow to select more than one. TM FX has not been designed to do what you do. You should use the EQs in your DAW software (Reaper) on the individual tracks/outputs instead.
