Topic: SPDIF in/out 9 pin breakout cable wiring
Hello
I have 9632 card .
i bought it used and it not included the 9 pin breakout cable for SPDIF
I have that 9 pin connector and need to wire up SPDIF (in)  on RCA .
which cable i preferable must use and which pin solder?
Regards,Taras.
Re: SPDIF in/out 9 pin breakout cable wiring
According to the manual pin 3 ( spdif in +) and pin 7 (spdif in -)
so if i right outer wire is negative inner is positive .....
and if i right 75 Ohm video cable is needed ?
Made it with 50ohm cable taken from wifi extension antenna cable  .....2 meter
looks like it working
shows (SYNK) mode in RME hammer panel
