Topic: Babyface Totalmix FX compressor change request
I own both UFX and Babyface and I really appreciate the opportunity to setup a zero latency monitor mix when recording vocals etc. But I miss the dynamics (compressor) in Totalmix FX when using Babyface, because I am used to have it for UFX. I do understand that the DSP in Babyface is limited and that is probably why it is only used for EQ. But would it be possible to have a choice of setting a limited numbers of EQ's and Dynamics that could be used, instead of having the possibility to use EQ on every possible channel? I never use EQ on every channel any way, but it would be very nice to be able to use a compressor now and then for at least one or two channels.
