Topic: Behringer BCF2000 - trim preamp gain + control FX send?
I have the Behringer BCF-2000 connected via USB in Mackie for Steinberg mode on Windows 8.1 laptop and I use an RME Babyface.
The submixes layout (Shift 1) on the Behringer BCF-2000 is different when I have the hardware inputs, playback or hardware outputs selected.
When I select 'submix selection in input/playback row' in TM settings and I am on the Inputs page, only the Main and Stereo submixes can be selected. Any other output selection (ADAT 1-8) is not selectable on the BCF-2000 when pressing Shift 1.
If I also check 'map stereo to 2 mono channels' in TM settings, this only applies when I am on the Outputs page. In Software Playback and Hardware Input view the submixes are still on two faders for Stereo.
1) Any ideas on how to select any submix when I am on the hardware input section? Preferably with stereo to 2 mono mapping, so I can view and select Main Out, Headphones and 4-6 monitors from any view on the Behringer.
Mysteriously, after connecting the BCF-2000 to Reaper and back to TMFX, selecting submixes works as expected! Solved.
2) Also, is it possible to trim preamp gain with the rotary controllers and control FX send?
