Topic: Multiple ports with Multiface
Hi, I have the Multiface 1. I tried to connect my Akai Max 49 to the midi port of the Multiface but I'm having a problem with the ports. The Max has multiple midi ports in and out but when I go into my DAW I can only see 1 multiface port for input and output. How can I get the multiface to recognize the other ports of my keyboard?
Re: Multiple ports with Multiface
You can't. The Multiface port is the only one your software will see. If you need the AKAI's ports, the keyboard has to connect to the computer with USB.
Ok. Thanks.
