Topic: Possible bug in HDSPe mixer (solved)
Hello!
I have a Multiface1/PCIe-cardbus connected to an PCIe->PCIe-cardbus adapter on my MacPro (2008) and a Madiface/PCIe-cardbus connected to a same PCIe-cardbus adapter model on another PCIe socket. Everything is working fine except for the HDSPe Mixer which moves the saved presets between those two units after reboots/cold startups. For example: When i save a preset on the Multiface unit with the name "Test1" it gets moved to the Madiface mixer after a reboot/cold startup. When i edit the mixer's .plist file and change the Lines named Preset from "Preset 1 (0)" to "Preset 1 (1)" then it works after a reboot, but only till the next reboot/cold startup. Maybe i'm just missing something, but i don't think this is normal, or is it? Btw, i'm not using the new Totalmixer since i really like the old mixer more, at least with my Multiface. Thanks for any suggestions.
