Topic: Old and New versions of TotalMix both installed
I am using FF400 with Windows XP.  I suddenly noticed today that I have both the old version (3.094) and new version (1.08) of Totalmix on the computer.  Apparently both work.  Driver version is reported as 3.114, and harware revision 1.71.
I normally use this computer with my UFX.
How can I uninstall the old version and keep the new one?
Thanks,
David
Classical ambisonic surround recording: UFX, FF400, Alesis HD24, Edirol R-44/88, Samplitude ProX 3.
Re: Old and New versions of TotalMix both installed
You can use the Add/Remove programs menu in Control Panel to uninstall. You probably need to reinstall the latest version again after this.
Thanks for your help, Jeff.  I followed your advice and now have just the new TotalMiX!
I had thought that this should automatically have been the case when I upgraded  Was I wrong?
David
