Topic: One HDSPe AES and Two ADI-8 QS
Hi All
Bored from latency, oversampling, stability ....... of others outboard finally i' m arrived to RME !
I' m going to by one HDSPe AES and Two ADI-8 QS. I was oriented in past toward HDSPe and two Octamic II...... but is not a perfect solution using a analog summing device ( I m not sure for the quality of DA conversion of Octamic II Out) Dont you??
So The question : The project is to use the ADI-8 for direct monitoring during records through HDSPe AES aes ebu out ,
                  but in "mastering mode" I will use the ADI-8 only like a DA converter to bring the signals
                  to a analog summing outboard ( SPL Mixdream for example ).
                  The stereo Mix is Send to a stereo AD converter and finally into a CD/DVD recorder.
What do you think of this setup ??
Excuse me for my not perfect english
Hi-z
Re: One HDSPe AES and Two ADI-8 QS
Octamic II has no D/A at all.
So the QS is a good decision. You could use it for A/D-Conversion behind the MixDream too.
Claudio
Of course !!
But i like very much rosetta 200 and "coda". It' s a good way to maximize a stereo signal before recording it.
However i can do the same with a analog mastering compressor after mixdream and the same QS.
Choices ..........i will think on it.......
