1 (edited by loopbreaker 2015-07-06 21:30:56)
Topic: Multiface II (PCIe) Ground Loop
Hi.
I have troubles with my Multiface, Mainbaord, Speakers and evrything get connected with the Ground from my Mainboard.
When i start the Computer, there is not a big problem, but if i start Cubase, than i can here the Computer work very loud from the speaker.
When my Synths only connected to the Multiface II (via Audio) there is no "noise", but if I put the Ground from the Mainboard to a Synth, a noise (like from the Speakers [here the Computer]) comes from the Synth to the Multiface II input.
For example: Minibrute only Audio and MIDI connected to the Multiface II = no problem > but when i plug the USB-Cabel from MINIBRUTE to the Mainboard, there comes a "computer noise" to the imput.
I tryed to use the Computer Powersupply instead of the PCIe Power, but this has NO effect.
I also forced my friends and some Froums to help me, but we can find no solution exept to put a 1:1 Transformer between Speakers and Multiface...
Has anyone an Idea, how i can get rid of this hell?
Thanks in Advance!
Re: Multiface II (PCIe) Ground Loop
I had the same problems and bought balanced (audio) cables and that fixed the problem.
Multiface has balanced In/Outs, so they work pretty well with balanced cables.
What do you mean by this? As in an external PSU?
I had group loop issues and using an external PSU to power the MF fixed my issues.
4 (edited by loopbreaker 2018-10-08 13:06:18)
Sorry, I've forgot that I had opend this thread.
Thank you all for helping!
The solution, for me, was a passive DI-Box with ground-lift.
http://www.palmer-germany.com/pro/de/PA … -PAN04.htm
Best Regards
