Topic: TCO use as Master WC out
Hi Guys,
I have a TCO and a Raydat connected in the PC.
Can I use the WC out as the Master WC without any video reference  ?
I want to send the wordclock from the Raydat to my interfaces.
Re: TCO use as Master WC out
The TCO's word output has been added just for this case, so that you don't need to buy another board (the WCM).
Thanks for the quick answer.
My sampling speed on the raydat is 44.1kHz tough on the tab input status the TCO lock is on 48kHz.
That's why I was doubting that the TCO could be sending out WC from the Raydat.
Anyway it is weird as the TCO tab says that the frequency is 44.1kHz
WCK Conversion set 1:1
The TCO holds the last sample rate when the input signal is missing. But the WC Out will be steered from the RayDAT when the clock settings are set correctly. Just try it.
