Topic: Phones out contact issue
I just bought an RME HDSPE AIO about a week ago. It was working fine until this morning. My issue is the following:
I can only have sound coming from both L and R when the cable is in a certain specific position. If I move the cable sligtly, I only get sound from the right channel, which is obviously pretty annoying.
It's not my headphones, as I've tested them on several other devices and I didn't run into this issue.
I also tried moving the card to another PCI slot with no success.
So my question is simply: is it likely the breakout cable causing the issue ? Or is it the card itself ?
I don't want to bring back the entire card if I can just replace the cable to fix the issue but I'm not sure.
Re: Phones out contact issue
Sounds like a broken cable to me.
