Topic: Gain Level in Totalmix
Hi
Im trying to understand the ufx and totalmix fx.
Arent there any gain control on the line inputs?
Are all input levels to the daw controlled by the external gear/instruments?
RME User Forum → TotalMix FX → Gain Level in Totalmix
Hi
The line ins have -10 dbV, +4 dbU and a 'low' setting. Those are not really used as gains - they are standard levels expected from 'pro' (+4) or 'consumer' (-10) equipment.
Only with preamps feeding the line inputs you'll have full control. But if you use them for keys or a git DI or whatever no one keeps you from using the most suitable of the three steps. As far as my experience goes it's not a practical problem. If I get levels between -25/-10 db I'm fine as long as I record in 24 bit.
If a signal is too low to get a proper headphone mix while recording it can be boostet with the dynamics section easily.
Ok. Sounds good.
Ill probably get used to this.
Thanks for replying!
