Topic: Freshly installed Totalmix on Mac Yosemite 10.10.3, but no window ??
BIG PROBLEM...
I just bought a new laptop as my old one died.
I have just installed the new version of totalmix, on my mac laptop running os 10.10.3....
BUT, when i attempt to open totalmix, i cant see the application's window at all.....
When i click to "open new totalmix window", the option, create new mixer or matrix window appears, but then nothing at all....when i try and choose...Zzzzz...so frustrating.
This is VERY urgent as i have a show tonite, and need this to work for it....
The interface itself seems to be workin perfectly...as i can see light indicators for incoming signal....
Sincerely appreciate ANY help on this.
Re: Freshly installed Totalmix on Mac Yosemite 10.10.3, but no window ??
Which interface is this? Which driver file did you install?
TotalMix will not open if the interface driver are not installed correctly (possibly a fault of permissions errors caused by the OS update) or if the interface is not detected.
Sorry..it was a FIREFACE UC...
I just installed V. 1.12 of totalmix
How can i check if the interface has been detected successfully ?
Should i de-install, and install an earlier version of totalmix that works with Yosemite 10.10.3 ?
What is the icorrect nstall/de-install protocol ?
6
Which DRIVER version did you install? Is the Settings dialog working? Is the UC in PC mode? Which firmware version does it have?
I thought the rme uc was in mac mode, as it worked perfectly with my previous laptop running a pre-yosemite version of OS..
How do i access settings ?
Ah thx...just double checked...and for some reason the internal on the UC had switched to PC...Just changed it back to AP, and it is working again ! Disaster averted...Cheers for the advice.
