Topic: Kemer Amp & UFX, wiring
am about to buy the Kemper Amp and want to rack it togeher with my RME UFX,
so that I have everything in 4 RUs.
Use cases are for me: Homerecording, reamping and gigging (if I dont want to carry tube amp with me).
In this case I want the UFX to connect everything else (Mics, Stage Piano) to act like a mixer
and recorder (DuRec).
I want to share with you my drawing in the hope that also other Kemper user use RME gear
to get some feedback in terms of cabling between UFX and Kemper amp.
As the Kemper rack version is a bit delayed here, I have some time for planning / cabling.
There are 2 things which I want to do, would be nice to get some feedback esp. in regards to this:
a) re-amping, I thought I use the SPDIF port for that
b) is it possible to connect the guitar to the RME UFX (Hi-Z) and then from analog out to Kemper ?
Then I could record my playing for any potential re-amping later.
Otherwise I would need to cable smth from Kemper "Direct Out" to UFX analog in.
What do you think would be better ?
