Topic: question about osc setSubmix
ive been trying to make my own osc template. in the excel file I found on the web with osc commands for total mix, there is a command setSubmix. the description is: Received value selects a submix directly, Numbering starting at 0 for single channels.
so I tried different combinations using setSubmix and some number between 0 and 9.. but it does work.. so how am I supposed to use this command.
I want to make make it easier to select submixes without first going to outputs etc.. smile
any help is much appreciated..
smile
gab
Re: question about osc setSubmix
Here is an example:
https://archiv.rme-audio.de/download/tm … uchosc.zip
Also check that you activated  '1'  in TM FX Options, Submix linked to OSC Control, or it won't work anyway.
ah.. that's how it works... thank you very much.
smile
gab
