1 (edited by doncl 2015-10-02 06:11:28)
Topic: HDSPE, El Capitan, Mac Pro 2013, Sonnet ExpressCard/34 compability
So, I just installed the hdspe_405 driver on OSX 10.10.5 (Yosemite), running the Sonnet T-Bolt to Expresscard/34 adapter, HDSPe ExpressCard/34 connected to Digiface and Multiface (alternately, usually the Digiface).
I've just downloaded El Capitan.
Can I install it?   Or should I wait a few months?  If RME is not sure I'd like to wait.   However, I use this Mac for iOS development also, and the moment Apple updates Xcode to a new version that only runs on El Capitan (and, from past experience, that will come sooner than later), I will be forced to upgrade, even if it means my RME hardware ceases to work or has problems.
So, what say you, RME?   Any ETA on when you'll know about compatibility as regards the configuration I just described?
Thanks,
Don
Re: HDSPE, El Capitan, Mac Pro 2013, Sonnet ExpressCard/34 compability
Have not tested HDSP drivers yet, but USB and Firewire work fine. That said, it is probably a good idea to install 10.11 onto a new partition, rather than just update the current installation.
I have 3 linked HDSPe cards working in a Sonnet chassis under El Capitan.
They work as well as they did under Yosemite.
