Topic: MADI over ethernet cable
Our larger live room is two floors lower than the control room.
When we use this live room, we let a 30m optical MADI cable run through the hallway. It's done in 5 minutes and way easer than working with a multicore. There is a MadiFace XT in the control room and an Octamic XTC in the live room.
The building we are in is an office building and it is fully equipped with Ethernet cables. There are at least 6 jacks in each room, a central patch bay and everything is Cat 6.
Is it possible to use the existing Ethernet cables to transport MADI?
Making a permanent installation of optical MADI cable would mean quite some effort including drilling holes through the walls. The ethernet cables are already there.
I was thinking of a media coverter like this: http://www.tp-link.us/products/details/ … 210CS.html
Those converters are designed for the opposite: to connect two copper networks over a long distance using optical cable. In theory I see no issues using them the way we need them, except the protocol.
Does that work? Has someone already make experiences with that?
Christian
