I now received the Startech USB-C to TB2 adapter. It works with the Dell XPS15 under Windows 10. I used the UFX+ directly into the Startech. I also used the Sonnet Echo Pro into the Startech to use Multiface, Digiface, RPM via the HDSPe ExpressCard. I used the MADIface ExpressCard. I even used the Netstor external PCIe chassis via its ExpressCard into this double adapter to use a HDSPe AES PCIe card. All of this works at lowest latency of 32 samples.
There are two problems though:
- Plug&Play is not working as expected. The audio interfaces will not be detected by Windows automatically. One has to insert the ExpressCard into the Echo, then connect the Echo into the Startech for Windows to react. Sometimes it is necessary to enter Device Manager, let it search for new hardware, and suddenly everything is there.
- Similarly one has to plug the FireWire audio interface into the Apple adapter, then insert it into the Startech adapter, oir the FW interface will not show up.
- The FireWire solution does not work perfectly, it causes a constant CPU load of > 20% on one CPU core. But audio and functions work. Maybe this issue gets solved later by updates from Intel and MS.
