1 (edited by guss 2015-10-30 17:43:28)
Topic: Putting filters on the outputs of total mix
Hello - I would like turn one of my adats into a digital crossover to put all my monitoring through ( am making a 3 way monitor system) . So I would like to have say 0 - 200 hz low pass filtered coming out of channels one and two, 200 hz - 2000 hz channels 3 and 4 - and above 2000hz channels 5 and 6 - is there an easy way to do this in total mix ?
TLDR; How can I put put filters on outputs of channels in total mix ?
Re: Putting filters on the outputs of total mix
If you still own a UC - there are no EQs available. You could only do this in your DAW software.
What is a uc ? I have a raydat with 4 adat outputs
Same same. No FX available.
