Topic: Pan problems with TotalMix in Control Room section.
Hi.
I have an "old" an reliable Fireface 400 running on Windows 7. My main monitors are a pair of Adam F5's and I want to use a set of Logitech Z623 as Speaker B monitors (a different reference). The Logitech speakers are a little louder on "L" speaker (I know that they are not high-end speakers and the diference it's just a little between L and R channels ).
I think the best solution is to use the PAN control in Speaker B in Control Room section of TotalMix with the mouse.
It works perfect! You can move the Speaker B fader without any problem... with your mouse only.
If you turn the rotary encoder on the FF400's front panel to raise the level, the pan control in TotalMix resets to "0" (center).
The "stereo setup mode" is activated in the FF400.
I prefer to use the front rotary encoder instead of changing windows in the PC.
It's there another way of doing this?
Thanks in advance...
Wilfredo Franco
