Topic: HDSP 9632 using ADAT & AES/EBU at the same time
hi,
i know the card doc says it can use all IO simultaneously,
but i notice in the DSP config app (bottom right tray icon) that i can only select a single option in SPDIF/in.
how do you configure it for both simultaneously ?
for simultaneous ADAT & AES output i presume i'd select Optical & Professional & check the XLR breakout option.
is this correct ?
can the 9632 actually do ADAT IO & AES IO at the same time ?
thanks,
Shaun
