Topic: babyface-> behringer ada 8200
I have a behringer ADA 8200 8 channel ADAT device that works well with my babyface.  I've used the inputs quite a bit on the behringer, but am now also interested in using the outputs.  I'd like to route seperate channels from my daw, through the behringer, then to an 8 channel external mixer.
I'm not having any luck... and am wondering how I would setup the totalmix routing to achieve this?
Cheers
Re: babyface-> behringer ada 8200
You'll need to set this up in the DAW application, send the individual tracks to the ADAT output channels.
