1 (edited by riffwraith 2015-11-24 16:50:35)
Topic: Two issues w/RME card
Hi - recently purchased an RME HDSPe AIO that I use with Windows7 Ult 64 bit. I used to have an M-Audio Delta card.
First - and this is a little thing - windows explorer does not click as I browse from folder to folder. Unless, I have WinAmp open and a file is playing. Any idea why this changed?
Secondly - and the bigger issue - I am no longer able to use Audacity to record system audio as I once was. I have tried every single option available, but unlike the M-Audio card, I can not record anything with the RME.
Ideas?
Thanks in advance.
Re: Two issues w/RME card
Check your defaults for input, playback, and system sounds in Control Panel > Sound
Where in Audacity? Or the RME panel? Don't see anything in the RME panel, and as I said,  I have tried every single option available in Audacity.
Thanks.
Solved the audacity issue. Any idea on the Win Explorer thing?
