Topic: Raydat card and TEB
Hi
Could someone please advise the correct way to connect the TEB expansion to the Raydat card.  Cant find it in any of the manuals.  Cheers.
Re: Raydat card and TEB
The internal connectors of the RayDAT are described on page 8 and even mention the TEB. The TEB manual has all the info needed, as the connection is the same for any internal card with internal ADAT I/O connectors.
There are no photos of the connections of the Raydat card in the TEB manual. Yes the Raydat manual mentions the TEB connections, but it doesn't mention how to identify which pin is ground on the Raydat card.
The ground pins from the five 2-pin connectors are all on top - to the outer edge of the card.
Thank you. All up and running.
