Topic: UFX in CC mode with ipad
I have just bought Auria for iPad.. I am wondering is there any way to setup the UFX inputs under CC mode so that you aren't restricted to just the first 22 inputs and you can assign a combination of hardware inputs to make up the 22 channels ? I would like to be able to use both ADATs and the 4 mic inputs... I don't need all the 8 line inputs on UFX and don't need the AES input.. Would prefer both ADATs, the 4 mics and would rather use 2 line inputs instead of the AES..
Im guessing the answer to this is, no its not possible ?? I see no mention of it in the manual but thought I would ask... If its not possible at this stage is it likely to change.. Do you have any way of making a matrix for CC routing ? Its a pain in the ass to be forced to take the 8 line ins and AES when its not how you want to use the device.
Re: UFX in CC mode with ipad
CC mode is not that flexible because poured into hardware, sorry.
