Topic: HDSP9652 expansion module with RAYDAT for Word Clock
Would it possible to use the HDSP9652 expansion module with the RayDat instead of the HDSP9632 Expansion module.
I noticed that the HDPS9652 uses connector x6 (14 pin) while the RayDat and HDSP9632 use the connector x102 (10 pin).
Im wondering if ten of the pins are the same, using an adapter to plug the 14pin into the 10, or is there other issues such as voltage for the expansion card to worry about.
I am considering the upgrade from my trusted HDSP9652 to the RayDat, but Im in a setup using a lot of BNC cables from external maseter clock (DTP) and Console (Yamaha 01v96) and will be adding an additional 8ch unit.
Thanks in advance
Re: HDSP9652 expansion module with RAYDAT for Word Clock
The expansion modules are not interchangeable.
