1 (edited by Hinfoweb 2015-12-09 10:33:44)
Topic: hdsp 9632 & Behringer Mini Mon 800
adjusting this settingfor the Rme hdsp 9632
http://img905.imageshack.us/img905/1796/mpjD5J.jpg
I notice that the audio output on Behringer Mini Mon always exceeds 0dB touching 6dB.
http://img903.imageshack.us/img903/8679/eb5L6u.jpg
To get the right decibel reference, I have to lower the level of the total mix of signatures to -6dB?
http://img633.imageshack.us/img633/9541/uytMPA.jpg
If the decibels on minimon 800, exceeding 0 dB means that the sound starts to go into distortion? Thank you
https://efrem-c-79.wixsite.com/efrem-c-79
Re: hdsp 9632 & Behringer Mini Mon 800
AFAICS, the Behringer uses a max of 15dbu on input as a spec, which is not a standard. +4dbu and -10dbv are standards and it seems the behringer is somewhere in between. If it were me I would put the RME output fader at 0db and the output setting at -10dbv. This will ensure full scale converter output of the rme minimize distortion at the behringer end.
Okay, thanks, in fact controlling the specifications of a signal input of 15 dBu, but by controlling the general specifications from these values ...
http://img908.imageshack.us/img908/9319/YZaxNV.jpg
+4dbu is not the maximum output on that setting of RME. With +4dbu the maximum level is +13dbu which is to much for the behringer.
Ok, thank
It would be nice that even signatures produce similar products to Minimon 800, perhaps with a better quality and technical characteristics, while maintaining a good quality / price ratio.
