1 (edited by spam1 2015-12-20 03:04:49)
Topic: Snapshots vs Layouts-2 Questions
Hello, this is my first post.
After a long absence from recording I have re-read the manual.
I am using FF 800 with TotalMix FX and have two questions.
1. I have only Playback channels 1+2 and 3+4 active.
I set all others to -infinity in the mixer, chose "Analog+SPDIF" in the bandwidth field of the Fireface settings, selected only 2 WDM devices in the settings as well, and went to Options-->Channel Layout-->Playbacks and hide them.
Still, with the exception of the AN5/6, AN7/8, and AN9/10, all the ADAT playback channels and the SPDIF playback channel show as being "In-Use".
This puzzles me because it only happens with the ADAT PB channels, not the ADAT Inputs or Outputs.
2. I can't quite understand the difference between Snapshots and Layouts. A snapshot stores mixer settings, including channels that show on the mixer. A Layout seems to concern only channels that show on the mixer. It seems to me that a Layout in this way, stores a subset of what can be stored with a snapshot. If this is the case, why have both layouts and snapshots? What am I missing?
Any help greatly appreciated.
Re: Snapshots vs Layouts-2 Questions
You use the latest driver and TotalMix FX?
Layout is just a visual thing and has no meaning in terms of working or not working audio channels.
Thank you for your response and sorry if I have caused any confusion.
My two questions are completely independent one from another.
I just grouped them under one post.
I understand Layout is just a visual thing but cant you accomplish the same effect by just storing a snapshot?
I am using TotalMix FX 1.12.
Konstantine
