Topic: Stand-Alone MIDI Remote Control (UCX)
Hi all,
I'm trying to control the UCX (stand-alone mode) through midi messages but unfortunately I'm not able to do this.
If the UCX is connected to the computer all is working as expected but not in stand-alone mode.
I need to control the sub-mixes (routing destinations) and the level of the sends.
Using the Makie-Control protocol the UCX is working correctly but if I use midi messages the interface is unresponsive.
So my question is:
Is it possible to control the UCX (sub-mix and channel-levels) with midi messages in stand-alone mode?
If it's possible, what are the messages we need to send?
Because the midi controls described in the manual (that works when connected to a computer) doesn't work in stand-alone.
Thank You!
Re: Stand-Alone MIDI Remote Control (UCX)
The manual clearly states the limitations in stand-alone mode. Only Mackie protocol will work.
Ok,
thank you for the fast response.
Is there any chance to see the midi implementation in stand-alone mode in future releases of the software?
This is not software, it is firmware, and there is no way to squeeze additional functionality like that into the UCX.
