Topic: Unable to stop FX Send when muting Input Channel with Group Mute
Hi Folks,
I spent quite a while searching for this answer, and I've come up empty.   I have had the UFX for less than one day, and I've got multi-track recording, including a M/S mic pair decoding correctly.  I've also got two headphone mixes setup as well as the control room monitors.
I've set up two Mute Groups, #1 mutes all of the hardware inputs for all of the routings that are active.  #2 mutes all of the software playback inputs for all active routings.  My problem is that the mute groups do not stop the channels from sending signal to their FX Sends, and I continue to hear the wet reverb sound even when the channels are muted.   If I press the mute button on a channel it mutes the channel in all routings and also mutes the FX Send from that channel.
Is there a way to stop the FX Send of an input channel using the mute groups?
Best Regards,
John.
