Topic: DSP EQ + D For Record
I cannot seem to figure this out by reading the manual.  If I want to "print" the DSP EQ and/or Dynamics to my recording, how do I select which mix's effects will print?  It is not uncommon to have different EQ settings for, say, and main monitor mix, and one or more headphone mixes.  In the event where there are multiple mixes, which one prints to the track?
2 (edited by demozic 2016-03-05 10:25:29)
Re: DSP EQ + D For Record
All submixes are sharing the same EQ/comp settings settings and FX Sends Level.
Also, printed tracks are "receiving" the Hardware input signals directly from the interface (just after the AD converters). Submixes won't affect the recorded signal sent to your DAW software (it's like direct outs of an analog/digital mixer board). If you Leave all the faders down to -inf, you will see you can still record input signals.
So basically :
If you uncheck "DSP EQ+COMP for Record", you'll get => direct out PRE Eq/Comp.
If you check "DSP EQ+COMP for Record", you'll get => direct out POST Eq/Comp.
RME UFX - TM FX 1.05 / Drivers USB 2.03 fw 1.58
Mac OSX.8.5 / Pro Tools 10.3.10+11.3.1 / VEP 5.3.1
