Topic: Ucx stand alone mode problems
hi, I'm using a ucx in stand alone mode with a Keith Mcmillen 12step pedalboard. I use the pedalboard for the snapshots change and the expression pedal for controlling the master output. It works but, when i change the expr pdl cc for controlling  the analog input volume or for controlling an output...nothing happens!!!! The cc are ok 'cause if i connect the ucx to my mac it works exactly.... What's the problem????
Re: Ucx stand alone mode problems
Connected to the Mac it is TM FX doing this, not the hardware. In stand-alone mode only the commands mentioned in the manual chapter '28.6 Stand-Alone MIDI Control' will work. And I don't see any CC mentioned there.
3 (edited by simonenobili67 2016-03-05 11:44:30)
but in the manual is wrote that I can control all the faders of the first and third row... so I was sending cc106 on midi ch.1 to control the fader of input n.5 ... is there another way for doing this? ( I'm using the ucx with 3 different guitars like a digital mixer)
My pedalboard can send ev'ry type of message, can you help me ?
Thank you
Obviously you control first and third row via Mackie protocol...
Then it isn' t possible to send a mackie protocol message with the Keith Mcmillen 12step pedalboard?
6
I can't answer that. You have to ask someone who knows that board.
ok, thank you !
Your board should be able to send PitchWheel commands instead of CC. As MC wrote CC are only supported in Totalmix and not in standalone mode. Again I recommend this pdf to translate Mackie commands to MIDI events. Don't forget: Mackie cannot address direct Faders as CC can do but only Banks of 8 Faders.
