Topic: Patient Anticipation
Your first IP-based interface can't come soon enough.
RME User Forum → Miscellaneous → Patient Anticipation
I can't understand why this kind of technology is not used as a commun standard. It will be the end of the USB2 3/Thunderbolt issues via a Cat 5e or Cat 6 gigabit Ethernet network, using the Ravenna (layer-3 audio-over-IP) protocol for example. An open protocol like Ravenna is fully compliant with the AES67 standard for inter-operability with other network audio devices. Simply plugged into a port on a gigabit router within a domestic wired network. When you see that Merging or Dad or others are using this protocol for years now...
