Topic: Sync problem with RME HDSP and ADA8000! HELP!
I'm having a sync problem that's driving me nuts.
My setup is as follows:
9652 ADAT 1 <-> Babyface ADAT (Slave)
9652 ADAT 2 <-> 9652 ADAT (Loopback)
9652 ADAT 3 <-> ADA 8000 (Slave)
9652 SPDIF <-> Coaxial Loopback
Now, ADA8k is where I've connected my mic inputs. And I see that it goes between Sync and Lock in the hammerfall settings. Sample rate is 48K. ADAT 1 and ADAT 2 are in Sync.
I've tried the following:
- Instead of ADAT 3 I tried ADAT 2 port to ADA8000. No luck.
- Set Babyface as Master and 9652 as Slave. Nope.
- Disabled PCI Express Root Port device having the same IRQ as 9652 in Device Manager. Nope.
Someone else is having this issue too : https://www.steinberg.net/forums/viewto … mp;t=60470
PLEASE help! It makes my mic inputs unusable (recorded audio has gaps whenever it goes out of sync).
