Topic: Totalmix open when i open the computer
hello,
Now, since few week, when i turn on my computer (apple Imac with OS Maverick ) i always see the software totalmix open, but i didn't open my UFX
i didn't make any update on the computer
why ?
last week i update the last driver ( 2016 ) but nothing happen, it's the same issue and it's the first time that i have this issue
If i put the icone ( of totalmix ) in the dock, totalmix didn't want to close
thank you for your answer
2 (edited by cyrano 2016-03-24 21:35:58)
Re: Totalmix open when i open the computer
I'm not certain I understand your problem.
Is the UFX connected? If yes, Totalmix should open. You can set that behaviour in Totalmix's preferences.
If the UFX isn't connected, you could be seeing a known OSX problem. When you shut down the computer, there is a checkbox to open the windows/programs you have open at shutdown again after you start up again. This doesn't always behave correctly. It opens window/programs even when they were not open at shutdown, or even when the checkbox isn't ticked.
I just recently saw the problem on my Mac after repairing the disk from the Recovery partition. After a second restart it went away. It seems to happen randomly...
I'm on 10.9.5 too and I only see this problem once in a while. Others are seeing it quite often. Apple doesn't care as the problem doesn't affect all users. Besides, they'd want us all to install El Capital.
thank you very much for this answer
yes my UFX is off when i see totalmix open
i thought perhaps to use time machine and terminal
thank you
ok i discover the problem
it's simply the soft totalmix appear in my list of app who start with the opening computer
